Door frame removal
Door frame removal
by htg engineer » Sun Nov 15, 2009 9:25 pm
I want to remove an internal door frame, which is in a load bearing wall. The opening will be boarded and plastered.
Will I come across any problems, will i need to install anything to support the brickwork above the door frame ?
Thanks htg
bd3cc
by bd3cc » Mon Nov 23, 2009 10:45 pm
If it is in a load bearing wall there should already be support for the wall above, as this should not bear on a door lining.
It is currently Fri Nov 22, 2024 3:19 am
