Watermarks on wallpaper
simpson49
by simpson49 » Sat Mar 03, 2007 3:15 pm
Condensation from the windowsill has run down onto the wallpaper leaving a nasty stain.
Any ideas of how I can rub it off.
NORMAN
by NORMAN » Sat Mar 03, 2007 6:48 pm
Had the same problem with the wallpaper stains, you'll see by my last topic thats it's back to the plaster time. Start with one layer of polystyrene veneer all over the external facing wall and see if this has any effect with the condensation on the window. I laid two layers and have reduced the condi' problem by 99%. B&Q knock the gear out approx £12 gives you 10 sq m.
sparrow
by sparrow » Wed Mar 07, 2007 2:56 pm
Good idea to deal with the condensation first. Addressing the effect is a continual job whereas addressing the cause need only be done once. Take a look at the condensation project on this website and introduce some ventilation to the area
thedoctor
by thedoctor » Fri Mar 16, 2007 12:55 pm
MANY OF THE ANSWERS TO YOUR POSTS CAN BE FOUND, WITH DIAGRAMS, IN THE DIYDOCTOR PROJECTS SECTION. CLICK HERE www.diydoctor.org.uk/projects.htm
It is currently Wed Feb 05, 2025 12:48 pm
