Hot water
how2
Hot water
by how2 » Fri Nov 20, 2009 3:13 pm
Hi all
I have a Vaillant Turbomax VUW 242/1Ecombi
The Hot water only comes on when the taps are open on full blast. When I open it slightly the boiler does not light up.
Only when I open the taps fully does the boiler light up.
Central heating is working fine.
whats wrong
thanks all
DEEARR2
by DEEARR2 » Sun Nov 22, 2009 9:16 pm
Movement of the domestic hot water through the Valliant boiler is monitored by a aqua sensor(flow generator) or a flow switch which signals the gas valve, at a predetermined minimum flow rate, to open. This would be the first thing to be checked. However, qualified gsr engineer required for any repair
