Load Bearing Wall
6 posts   •   Page 1 of 1
jez937
Load Bearing Wall
by jez937 » Mon Nov 23, 2009 8:16 am
Hi All, I hope someone can help. We are hoping to make some adjustments to our loft to increase the living space in our bungalow. We have removed a window from what was an external wall and above this is a 7" x4" length of wood which sits on the brick. Will this suffice as a lintel or do I need to reinforce this with a catnic lintel?
Many thanks.
Perry525
by Perry525 » Tue Dec 08, 2009 6:04 pm
I am not sure I understand the question. But here goes.......
First of all is the wall load bearing - if it is take extra care.
If it is not load bearing then all a lintel does is support the weight of the wall inside a triangle of 45 degrees from the edges of the opening.
Brick comes in around 45 kilos/one hundred weight a cubic foot.
For an opening the size of a typical door, no problem.
As an opening gets wider you need to take into acount the damage the masonary will do if it falls and provide support while working. You will also need a suitable steel lintel - keep in mind you will have to lift the lintel into place and these things can be heavy.
benyboy
Re: Load Bearing Wall
by benyboy » Thu Jan 28, 2010 8:54 am
[quote="jez937"]Hi All, I hope someone can help. We are hoping to make some adjustments to our loft to increase the living space in our bungalow. We have removed a window from what was an external wall and above this is a 7" x4" length of wood which sits on the brick. Will this suffice as a lintel or do I need to reinforce this with a catnic lintel?
Many thanks.[/quote]
I would always get an engineer in to confirm any structural calculations - especially if you have a loft conversion above any structures that you are altering
TheDoctor4
Local help at hand!
by TheDoctor4 » Thu Jun 24, 2010 10:14 pm
If you would like to find a reliable, insured and vetted tradesman in your area why not click through to the Find a Tradesman area of DIY Doctor: https://www.diydoctor.org.uk/find_tradesmen/ , complete the form and receive up to 5 FREE quotes
DevilDamo
by DevilDamo » Mon Jul 12, 2010 7:41 pm
Why do you need to do anything with the existing lintel/support?
Eva2100
reply
by Eva2100 » Wed Aug 04, 2010 7:21 am
wish you have solved your prolem..
It is currently Sun Dec 22, 2024 5:18 pm
