Kitchen Spotlight
7 posts   •   Page 1 of 1
jazp1970
Kitchen Spotlight
by jazp1970 » Mon Nov 23, 2009 12:05 pm
I removed an old light fitting in my kitchen and replaced it with a 3 spotlight bar fitting after wiring it according to the instructions supplied only one spotlight ( the middle of the 3 ) works any suggestions ?
bd3cc
by bd3cc » Mon Nov 23, 2009 11:20 pm
2 of the internal connections are not bproperly connected.
kbrownie
by kbrownie » Mon Nov 23, 2009 11:57 pm
Are all the terminals tight and correct on the other lamps are the lamps(bulbs :? ) okay
acsimpson
by acsimpson » Tue Nov 24, 2009 11:08 am
Spotlights I have installed in the past have sepearate flexes for each spot which are joined in a connector strip. The supply then comes into this strip from the other side. If only one light is working but all three flexes are in the strip it may be faulty, in which case return it to the shop you bought it from.
jazp1970
by jazp1970 » Tue Nov 24, 2009 11:58 am
Not sure if the problem is that there is only one wire from the ceiling
acsimpson
by acsimpson » Thu Nov 26, 2009 10:10 am
I'm no expert on the different forms of wiring for lighting circuits, however if one of the lights is on then as long as all the wiring in the light fitting is correct you shouldn't need any more cables from the ceiling.
Power is being supplied down one cable and it should be sufficient to supply more than 3 spots.
marconii
Re: Kitchen Spotlight
by marconii » Sun Nov 29, 2009 6:03 pm
[quote="jazp1970"]I removed an old light fitting in my kitchen and replaced it with a 3 spotlight bar fitting after wiring it according to the instructions supplied only one spotlight ( the middle of the 3 ) works any suggestions ?[/quote]
hi im an electrician.....MW ELECTRICAL....CARLISLE..
assuming that one of the lights are working...check you havent pulled any wiring away from the light fitting itself......accidentally occuring whilst you have wired it up......it happens to me, and ive been a sparky since 1982.
asuming everything is fine and there are no loose wires from the fitting...
check you bulbs are ok...check that they are fitted securely....
trust me.....it will be one or the other.....
let me no how you get on.
Mark ..
It is currently Fri Nov 22, 2024 2:16 am
