Draft from under the first floor level
waherne
by waherne » Mon Nov 23, 2009 12:53 pm
I have a serious draft from under my first floor bedroom, the ground floor room below the bedroom is also approx 8 degC colder than the rest of the house. When I lift a small section of floor boards at first floor level, its similar to opening a window! The bedroom is located at the back of the house, where there is also a tiled roof on the ground floor extension to the back of the house.
1. Would sealing with foam or Rockwool in-between the floor joists along the external wall at the perimeter solve this problem? or alternatively completely insulating between the first joists running parallel to the back wall?
It is currently Sat Dec 28, 2024 4:45 pm
