Is one 1/2 inch feed to a bath enough?
yrrab
by yrrab » Sat Nov 28, 2009 10:36 am
I am fitting an overflow fiiler to a bath. There is only one 1/2 inch inlet. I assume I have to mix the hot and cold feed through a 15mm T joint before I send it to the filler. Will there be enough pressure to fill the bath at a reasonable rate? The bath I took out had two 22mm feeds. The hot water is delivered through a combination boiler which is a condenser.
rosebery
by rosebery » Wed Dec 02, 2009 10:49 pm
See answer on your other thread.
It is currently Sun Nov 24, 2024 5:48 pm
