Do check valves restrict flow rate
barryomoss
by barryomoss » Sat Nov 28, 2009 7:51 pm
I am fitting an overflow filler to my bath. I have been told that check valves are necessary to prevent any waste getting back into the water supply. Are they really necessary and will they slow down the flow rate into my bath?
speedygonzarlis
by speedygonzarlis » Wed Dec 02, 2009 9:57 pm
if you have a gravity system and your header tank isnt so high you may get a restriction of flow, if combi or unvented should be fine.
rosebery
by rosebery » Thu Dec 03, 2009 12:05 am
Yes they are required. Flow rate will be marginally affected.
barryomoss
by barryomoss » Sun Dec 06, 2009 5:02 pm
Thanks speedygonzarlis and rosebery.
It is currently Wed Feb 05, 2025 1:50 pm
