SHOWER TRIPPING
aldino
SHOWER TRIPPING
by aldino » Sun Nov 29, 2009 10:08 pm
HI,MY 9.5KW TRITON SHOWER KEEPS TRIPPING THE MCB WHEN ON THE SECOND HEAT SETTING.ITS OK ON HEAT SETTING 1.THE RATING ON THE FUSE IS 50AMPS.IT WAS FINE FOR A WHILE THEN MAYBE ABOUT 6 MONTHS LATER THIS PROB APPEARED.ANY HELP?
steve the plumber
Re: SHOWER TRIPPING
by steve the plumber » Wed Dec 02, 2009 2:15 pm
[quote="aldino"]HI,MY 9.5KW TRITON SHOWER KEEPS TRIPPING THE MCB WHEN ON THE SECOND HEAT SETTING.ITS OK ON HEAT SETTING 1.THE RATING ON THE FUSE IS 50AMPS.IT WAS FINE FOR A WHILE THEN MAYBE ABOUT 6 MONTHS LATER THIS PROB APPEARED.ANY HELP?[/quote]
Check the connections in the shower and the isolation switch.
rosebery
by rosebery » Wed Dec 02, 2009 8:16 pm
What was the power rating of the shower that the Triton replaced? Did you replace it or did you employ a professional?
It is currently Wed Nov 27, 2024 10:11 pm
