Mains water pipe needs cutting off?
wightie
by wightie » Sat Jun 02, 2007 6:57 pm
High,
Can anyone give some advice please. I have two water mains pipes coming onto the house.
One is used the other is dormant and the stop cock is turned off, but it still leaks. It is quite an old pipe, and a plumber who did some work for me reckoned it couldn't be sealed of, as it was an old pipe which parts were not made for anymore.
Surely there must be some way of sealing it of permanetly, the dripping has become pretty serious.
Any ideas?
cheers
JP
by htg engineer » Sun Jun 03, 2007 6:03 pm
there should be a stop tap outside, this will stop the water so that the pipe can be blanked or new stop tap fitted, if the external stop tap cannot be found, you can use freezing equipment to freeze the water and then blank the pipe off.
It is currently Mon Dec 23, 2024 10:09 am
