make tiles non slip
twina
make tiles non slip
by twina » Tue Dec 01, 2009 9:32 am
i am just about to rent my house out to a young couple as i am moving in with my partner. I own a Victorian terraced house which is set back from the road. Between the front door and the road there is a tiled path, which is the original path and is very stunning. The problems is that if it gets icy then the path can become slippery. i don't not want to rip up the path if i can help it, so i was wondering if anyone had any advice as to whether there is a product which can be sprayed on or painted on and that is see through on the market that will last for a good period of time and make the tiles non slippy. #
thanks in advance.
DOTTER 1958
Re: make tiles non slip
by DOTTER 1958 » Tue Dec 01, 2009 9:42 pm
[quote="twina"]i am just about to rent my house out to a young couple as i am moving in with my partner. I own a Victorian terraced house which is set back from the road. Between the front door and the road there is a tiled path, which is the original path and is very stunning. The problems is that if it gets icy then the path can become slippery. i don't not want to rip up the path if i can help it, so i was wondering if anyone had any advice as to whether there is a product which can be sprayed on or painted on and that is see through on the market that will last for a good period of time and make the tiles non slippy. #
thanks in advance.[/quote]i would use unibond mixed with building sand dries clear but please try a little patch first and only apply when dry and not frosty.
twina
thanks
by twina » Wed Dec 02, 2009 8:44 am
thanks for taking the time to reply
when you say unibond do you mean the PVA adeshive? sorry there are many unibond products.
thanks
DOTTER 1958
Re: thanks
by DOTTER 1958 » Wed Dec 02, 2009 8:01 pm
[quote="twina"]thanks for taking the time to reply
thanks[/quote]yes pva adeshive. used to use granite dust rather than sand but sand should be fine.
It is currently Thu Jan 09, 2025 3:47 pm
