Garage base that needs to be changed
LiamD
by LiamD » Mon Dec 14, 2009 9:52 pm
Evening all,
Not the best at describing things but here goes.
I have large rectangle concrete floor with footings all around for a 2 leaf cavity wall which currently is 2 blocks above floor level. In otherwords the base of a garage with 2 rows of blocks up all round.
I want to put a 2 leaf cavity wall across the span of the floor to approx 7' high. I assume i'll have to cut the floor and dig to the level of the outside footings and lay footings for this new wall.
:?: Is it neccessary to join the new and old footings in some way or is it ok to pour to the same depth and height as the old footings, :?: do I need to use some steel as the span is 17', or is this necessary or is there some other way of doing it
LiamD
Perry525
by Perry525 » Sat Dec 19, 2009 6:54 pm
You must have planning permission to change the design of your project.
Go back to the Council with your proposal and ask their advice.
elwood
by elwood » Sat Dec 19, 2009 7:36 pm
hi
you don't need planning but you will need building control.
depends on the building inspector regarding wheather he will ask you to fix the old to new footings .
yes dig down to the existing level of the existing foundation and this should suffice.
Bye.
LiamD
by LiamD » Tue Dec 22, 2009 8:35 pm
Thanks for the advice guy's
[quote="elwood"]hi
Bye.[/quote]
TheDoctor4
Help from DIY Doctor!
by TheDoctor4 » Thu Jul 01, 2010 8:55 pm
For up to 5 FREE quotes from trusted, vetted and insured tradesmen in your area visit the DIY Doctor Find a Tradesman page: https://www.diydoctor.org.uk/find_tradesmen/
It is currently Wed Jan 08, 2025 3:10 am
