satallite tv links lost after change over
jjsingleton101.wanadoo.co
by jjsingleton101.wanadoo.co » Tue Dec 15, 2009 12:41 pm
HI
I currently have sky tv set up in my lounge and wired through a link to all rooms but since the digital change over i only get digital channels in the other rooms.Does anyone know how i can rectify this?
cheers Phil.
by ericmark » Tue Dec 15, 2009 11:35 pm
Most likely cause is there is now a freeview channel on same frequency as the sky box outputs.
On sky remote press: services 4,0,1 select, that will bring up the installer menu, then the RF channel number. Default is 68 and it can be anything between 21 and 68 sometimes sets will tune to 69.
Big problem is to find what channels are now in use. Changes area to area. Some TV's will tell you what channel they are on.
sky reception
by jjsingleton101.wanadoo.co » Wed Dec 16, 2009 11:04 am
Hi ERICMARK
Thanks for the advice,it worked a treat.Have a great christmas,Cheers Phil.
It is currently Mon Jan 06, 2025 8:33 pm
