Hi All, I've got a uPVC Window which does not close evenly on both sides. When its closed fully the hinge side does not press against the rubber seal so the gap between the sash and the frame is about twice what it is on the latch side. Its a simple hinged window, no fancy moveable hinges or anything like that.
From what I can see there are two triangular plastic pieces attached to the sash top and bottom and they engage with two other plastic pieces attached to the frame which have corresponding cut-outs. There doesn't appear to be any adjustment, nor does there appear to be a way of replacing these pieces without replacing the complete hinges.
Is this right? or have I missed something? :?
