boiler wont light
6 posts   •   Page 1 of 1
wayne 78
boiler wont light
by wayne 78 » Sun Dec 20, 2009 8:33 pm
hello everyone. my boiler a worchester bosch 24i greenstar. wont work in hot water or heating/wen i switch it on it makes like a wooshing sound but the main burner will not come on any ideas anyone thanx .
fordy
by fordy » Mon Dec 21, 2009 11:31 am
my com-by boiler not working through the night and found the pipe that takes the condenser water away out of a separate pipe had frozen up out side and the water backed up to stopping the boiler from lighting <fault code 6a on mine ,just remove pipe and let the water run into bucket under boiler ,,this not radiator water just but part of the condensing water discharge
fordy
by fordy » Mon Dec 21, 2009 12:30 pm
My boiler combi not working through the night and found the discharge pipe from the bottom of combi boiler had frozen up outside and the water had backed up <filing the pipe back up to the boiler > and caused the burner not to light, I just removed the discharge pipe which is normally plastic pipe going outside or to a drain out side of your house to let the condensed water run off ,,,, make sure you know which are gas pipes and don’t play with these, read your manual to know what pipes do what
by htg engineer » Mon Dec 21, 2009 5:41 pm
All external condensate discharge pipework should be 1.25" - if it's not it can freeze.
You're supposed to fill the condensate trap with water before running the boiler, if the condensate trap is emptied you could get fumes from the condensate pipework (only for a very very short period of time)
htg
wayne 78
by wayne 78 » Wed Dec 23, 2009 12:46 pm
thanx guys it was the condensate pipe frozen
by htg engineer » Thu Dec 24, 2009 9:08 am
I bet the condensate pipe is undersized.
htg
