flame failure on performa 24 eco he
peterhiggs
by peterhiggs » Sun Dec 20, 2009 10:53 pm
im getting flame failure on my boiler,any ideas why this is happening,sometimes have to reset it en times to get the flame working again,thanks
rosebery
by rosebery » Mon Dec 21, 2009 9:39 am
Flame Failure Light on this beastie means you have a problem and if it contues to be lit after several attempts at restart it isn't transient. It will not be a DIY job. I'll bet the user manual says "Contact Your Installer Or Service Engineer"
I really think that is what you should do.
by htg engineer » Mon Dec 21, 2009 5:45 pm
Could be a simple 'flame failure fault' - lazy gas valve, faulty ignition/flame sensing electrode etc etc
But could also be a flue fault, if there's a break in the flue the combustion gases mix with the return air within the flue - the flames will start to search for oxygen and lift off the burner/electrode.
RGI needed
htg
It is currently Tue Jan 07, 2025 5:59 pm
