by Perry525 »
Wed Jan 06, 2010 6:55 pm
The warmest place in a room is between the radiator and the wall behind it.
A vast amount of heat from a radiator is lost heating the wall behind it, or the window above it, and often the world outside.
With a double radiator more of the heat will get into the room but, the comfort factor relies on radiant heat, while most of the heat is convected rising to heat the walls and ceiling and this is lost to you. A better idea is to follow the continental system, which is to fit radiators sized 50% bigger than you expect to need.
In real life the cost difference cannot be certain, but the comfort will be noticed.
