Insulating Cold wall in bathroom
markyuk
by markyuk » Tue Jan 05, 2010 7:30 pm
Hello im trying to find out best way to insulate my bathroom wall
The wall gets so cold as its an outside solid brick wall not cavity
so it gets very cold and then causees a lot of mosture
so i have decided to rebuild the room and try to insulate it
what ihave decided is to make a studwall on to the existing wall and use gyproc 40mm thermaline plus i understand there should be an air gap between existing wall and the back of the foam on the board.
what do peole think would you use that board or moisture board and something like celotex for insulation
the thermaline board is quite cheap compaired,
also would i need a vapor barrier behind
many thanks
Mark
TheDoctor4
Help from DIY Doctor!
by TheDoctor4 » Fri Jul 02, 2010 9:09 pm
If you would like to find a reliable, insured and vetted tradesman in your area why not click through to the Find a Tradesman area of DIY Doctor: https://www.diydoctor.org.uk/find_tradesmen/ , complete the form and receive up to 5 FREE quotes
It is currently Tue Nov 26, 2024 5:04 pm
