New Electric oven
Fishie42
New Electric oven
by Fishie42 » Wed Jan 06, 2010 10:55 am
I am replaceing a built in electric single oven and hob with a freestanding electric double oven and hob.
The oven is currently just plugged into a wall socked, the hob is wired into a switch (red oven type switch) which is off the main fuse box.
I know that the new oven will need to be wired into the main fuse box through this existing switch that the hob is currently wired into!
I would like to get an electrician in to do this and check that the wire that is there is adequate, but im not sure how much I may get charged. I can get the oven from a different source that would be £100 more but they would fit it!
Any help on a cost estimate would be appretiated!
Lucy
BLAKEY1963
by BLAKEY1963 » Wed Jan 06, 2010 8:40 pm
FISHIE42
If wiring is in order and intallalation conforms to current
regs , after mandatory tests and inspections are carried out
then in my area , with relavant certification , i would charge
a lot less than £ 100 pound and i am NICEIC registered.
You need to get a quotation from a part p registered electrician
in your area to get accurrate costings. Rates do vary.
BLAKEY1963
by sparx » Thu Jan 07, 2010 5:08 pm
hi, as Blakey says, as long as existing oven switch is fed from a fuse/mcb of 30/32A rating then should be straight forward changeover taking no more than 1hour at local rate (£30 + vat me in rural area) check for registered leckie locally, from one of the government schemes or via
'Trustmark' or trading standards 'Buy with confidence' web sites,
regards Sparx
It is currently Fri Nov 22, 2024 1:21 pm
