installing a shower pump
griff.larco
by griff.larco » Wed Jan 06, 2010 8:23 pm
Hello & Bonjour
I have just installed a wood-burning central heating/hot water system. The system is vented and I have followed the manufacturer's installation instructions along with a modicum of advice from an experienced plumber.
My problem now seems to be a lack of head between my cold water tank and shower/tap outlets, giving me a very poor flow from bath and basin taps. (I haven't connected the shower room to the system yet, but as this is at a similar level to the bath, I know the flow will be just as bad). I am unable to raise the cold water header tank.
Can I install a shower pump to supply the bath and basin, as well as the shower? Am I likely to over-ride the supply by running the bath, even with a Surrey flange fitted? Am I totally daft even to consider doing it?
plumbbob
by plumbbob » Fri Jan 08, 2010 12:51 am
You will need two pumps. A single impeller for the basin and bath hot and a twin to pump both hot and cold to the shower.
Your problem is going to be with the expansion pipe and air being drawn into the pipework. A Surrey or E-s-s-e-x flange will reduce the risk but if the header tank is very low a risk will remain.
It is currently Wed Jan 08, 2025 4:05 pm
