Mains water pump with combination boiler
glendadexter
by glendadexter » Thu Jan 07, 2010 1:45 pm
I was wondering if anyone can advise me as to whether I can fit an electric pump to the mains water pipe with a combination boiler? In the summer in particular we have very low mains water pressure, to the point where our comination shower does not work, so thought I could fit a pump that I could start up when the pressure was too low?
by htg engineer » Thu Jan 07, 2010 7:48 pm
It is against water regulations to pump mains cold water.
Basically if there's any break in the pipework under ground expecially next to sewers etc you could be pulling waste/contaminated water into your drinking supply.
htg
glendadexter
by glendadexter » Fri Jan 08, 2010 7:59 pm
[quote="htg engineer"]It is against water regulations to pump mains cold water.
htg[/quote]
Thanks for this information, I wondered whether there was a restriction on this! Well sounds like we will have to put up with the occation morning when we cannot shower unless we go back to a conventional boiler and header tank.
Thanks Glenda
It is currently Wed Jan 08, 2025 3:48 pm
