Radiator Thermostatic Valve size
markyuk
by markyuk » Thu Jan 07, 2010 10:37 pm
Hello just trying to find out some info
any one know what size allen key i have to use to get the bottom pipe out of the rad so i can fit a thermo valve as it has a allen key head inside the pipe, and i need to get it off to put the new one in that came with the thermostaic valve as new vale is 15mm going in to rad.
old one looks like a 22mm size union on it
many thnaks
Mark
chris_on_tour2002
by chris_on_tour2002 » Thu Jan 07, 2010 11:30 pm
go into any plumber's merchant and ask for a radiator key - don't confuse it with a bleed valve key. should be a standard size, though there are some oddities out there - if so get a universal radiator key.
this is a standard key (or spanner as they call it here):
http://www.awin1.com/awclick.php?mid=12 ... or-Spanner
universal key looks like this and should fit all rads:
Google "amazon.co.uk/Monument-2052r-Universal-Radiator-Valve/dp/B0001P0FGS"
tsb
by tsb » Thu Jan 07, 2010 11:35 pm
Off the top of my head ,I can't think of the size but I know in my area the local pound shops sell them. And before you ask, they are a pound
rosebery
by rosebery » Thu Jan 07, 2010 11:39 pm
Radiator Spanner (Screwfix do 'em) or;
14mm allen key usually works or;
A large flat bladed screwdriver
Top one is the proper item but the others work too.
markyuk
by markyuk » Fri Jan 08, 2010 11:06 pm
thanks very much indeed, went to screwfix and brought one perfect
MArk
It is currently Fri Nov 22, 2024 5:30 pm
