Kitchen worktop planning
santamed
by santamed » Thu Jan 07, 2010 11:48 pm
In the tips it advises not to put an inset sink near to a worktop join. Is it ok to overlap a joint with an inset sink? say by a couple of inches
chris_on_tour2002
by chris_on_tour2002 » Fri Jan 08, 2010 9:36 pm
not recommended unfortunately.
firstly you will drastically reduce the integral strength of the worktop. secondly it invites moisture ingress, resulting is swelling.
jackthebuilder
by jackthebuilder » Sat Jan 09, 2010 11:51 am
Chris is absolutely right - don't even attempt it.
Can I suggest:
1 - you either re-plan your worktop layout such that the inset is away from the ends of a longer run,
2 - see if a right hand or left hand drainer would make a difference to the positioning,
3 - (last resort) see if you can get a sink with a drainer that doesn't need to be part of the cut-out, and the drainer could then overlap the joint, but the cuts will have to be spot-on, the cuts sealed with at least 3 coats of varnish or whatever, and the worktop connectors properly fitted.
Good luck!
Jack.
It is currently Fri Nov 22, 2024 8:45 am
