Towel radiator
pc6844
Towel radiator
by pc6844 » Fri Jan 08, 2010 8:53 pm
Hi, is 2068 BTU from a towel radiator in a bathroom, sized 2m x 2m an adequate amount of heat to heat the bathroom?
by stoneyboy » Mon Jan 11, 2010 9:53 pm
pc6844,
If all walls are internal and no window - yes. Otherwise - no.
If you hope to cover the TR with towels you will get very little heat.
chris_on_tour2002
by chris_on_tour2002 » Mon Jan 11, 2010 11:17 pm
a rule of thumb is:
L x W x H (in feet) x 5.5
this gives an estimated requirement of around 2,100 BTUs so you should be fine with this, provided that your ceilings are no higher than 8ft, which is what i allowed in the calculation. (bear in mind heat rises, so higher ceilings would simply allow all the warm air rise above a useful level).
as i said however the above formula is only a rule of thumb. factors such as double glazing, loft & cavity insulation etc also need to be taken into account. also worth checking to ensure your boiler has the necessary capacity.
It is currently Fri Nov 22, 2024 7:08 am
