no hot water after 3-4pm?
glousey
by glousey » Sat Jan 09, 2010 9:09 am
hello,
we have an immersion heater which is hooked up with 2 switches because of economy 7 electricity. Recently we have not been getting hot water from about 3pm (the switch for the top up element is on with a red light). we called in a plumber who took a look at it and tried to blame it on the economy 7 side of things and that he could not do anything because he was not an electrician, he did not seem to really check out the heater much.
Does this sound like a plumbing issue or an electric one?
by stoneyboy » Mon Jan 11, 2010 9:48 pm
glousey,
Economy 7 comes on 12-7am or 1-8am depending on BST. It would be normal for the top element switch to be off (this is used for boosting hot water). Checking whether the elements have burned out is straightforward and any plumber should be able to do this.
You could check whether the clock on your economy 7 controller is set correctly it will be in the meter cupboard.
It is currently Fri Dec 27, 2024 5:23 pm
