Wiring a dimmer switch with 4 connections
johnpw22
by johnpw22 » Sat Jan 09, 2010 5:50 pm
My daughters bedroom dimmer just broke, so I hunted my workshop and found a replacement - but its connections are labelled 1, 2, 3, and 4 only. The original just had two wires and earth... live and neutral - easy, so which connections do I use to avoid blowing it up. It is switched and fused...? Thanks!
chriscba
by chriscba » Sat Jan 09, 2010 10:16 pm
You have got an intermediate switch, but you can still use it, use 1&3,
johnpw22
by johnpw22 » Thu Jan 14, 2010 7:41 pm
Thanks for that - just checking - is 1 live and 3 neutral, or doesn't it matter?
It is currently Fri Jan 17, 2025 1:44 pm
