Gap between window frame and brickwork
ayegee
by ayegee » Mon Jan 11, 2010 5:50 pm
When new frames are fitted should there be a weather bond or gap fill be fitted between the frame and the brickwork. In some cases on my installation there seems to be about a 1inch gap and all that is covering the gap is a strip of plastic moulding fixed with the type of sealing you get around a bath, is this right.
by stoneyboy » Wed Jan 13, 2010 9:03 pm
ayegee,
Sounds like the windows were not the right size, remove the plastic moulding a fill the gap with expanding foam, then refit the moulding.
It is currently Mon Dec 23, 2024 10:00 am
