painting a upvc door
jerympatrick
by jerympatrick » Wed Jan 13, 2010 7:13 pm
How do I prepare a upvc door for painting?
regards jerym
have searched the previous questions but found nothing
theshedman
by theshedman » Thu Jan 14, 2010 9:29 am
Hi, the simple answer is not to do it. Upvc is not really made to be painted and the chances of it staying on without some of it peeling are slim. Dulux do make a upvc paint but I think it only comes in white, just in case you wanted a different colour. There is a product called ESP which is used to prime plastic which you could use to get it ready for painting if you decide that you want to go ahead with it. Just follow the instructions and hope for the best. Good luck.
chris_on_tour2002
by chris_on_tour2002 » Sat Jan 16, 2010 12:22 am
you can't. even with products designed for the job the results will not be satisfactory. better off trying to clean the pvc, unless a colour change is required. in which case better to buy a new door.
It is currently Mon Dec 02, 2024 4:26 pm
