installing a security light - new project
souterjohnny
by souterjohnny » Thu Jan 14, 2010 11:09 am
Can I use an existing 1mm cable to install a 500 watt security light?[b][/b]
by ericmark » Fri Jan 15, 2010 11:58 am
Very likely but the council may have some restrictions I am sure you are aware over 150W requires permission from local council.
Yes I know that discharge lighting should not be switched with PIR it should just go on at night and stay on so although a 70W Metal Halide lamp give more light than a 500W Quartz it is on longer.
But I didn't make the rules.
It is currently Fri Jan 17, 2025 3:22 pm
