by theshedman »
Tue Jan 19, 2010 12:16 pm
Hi ukbill, as Chris says it will be caused by condensation. As he says use a mould and mildew remover, I always use the Dettox one and find it works well. If the mould is bad you may have to use it more than once though. Make sure that you don't miss any though as if you paint the walls and you haven't got rid of all of it, it may start growing under the new paint. The other things you can do to help prevent it apart from the ones Chris says are 1, put a Dehumidifier in the room which will help remove the moisture from the room and 2, get more heat into the room to keep it drier. Good luck.
