Blocked stub stack
Loweyk
Blocked stub stack
by Loweyk » Sun Jan 17, 2010 8:00 pm
It seems i have a blocked stub stack with no access. The stack joins the drain run via an 87degree T junction with no access to rod and the stack itself is capped off and hidden behind plaster board. Was wondering if there is anything i can pour down the toilet to break down the blockage?
thanks in advance for any replies.
plumbbob
by plumbbob » Sun Jan 17, 2010 10:12 pm
It is unlikely anything poured down a toilet will remove a blockage. A good place to start is to use a large plunger.
It is currently Thu Dec 05, 2024 2:06 am
