Removing glued feet from furniture
davem
by davem » Sun Mar 04, 2007 1:17 pm
I ned to replace the feet on an old piano stool to lower its height, but cannot get 2 of the feet off. They are glued in securely. Is there any way of breaking down the wood glue? I really don't want to cut the feet off, because at some point in ther future I may want to put them back on again.
The stool is probably > 50 year old. Any help would be much appreciated.
thedoctor
by thedoctor » Sun Mar 04, 2007 9:53 pm
Heat is usually the only way to break down wood glue Dave but the amount of heat required is usually enough to burn the timber ! Very sharp chisels and/or a hobby knife is usually the only way which retains the integrity of the piece.
thedoctor
by thedoctor » Fri Mar 16, 2007 12:14 pm
MANY OF THE ANSWERS TO YOUR POSTS CAN BE FOUND, WITH DIAGRAMS, IN THE DIYDOCTOR PROJECTS SECTION. CLICK HERE www.diydoctor.org.uk/projects.htm
It is currently Mon Jan 06, 2025 8:58 pm
