flue fitting regulations
commmike
by commmike » Wed Jan 20, 2010 6:23 pm
What are the regulations concerning the fitting of flue on a gas boiler? Is there a minimum distance that a horizontal flue should be positioned away from PVC guttering on the external wall? Where do I find the regulations?
Thanks for any help you can provide.
thegasman
flue
by thegasman » Sat Feb 27, 2010 9:55 am
if you need to ask these questions you should be seriously asking yourself if you should be fitting a boiler in the 1st place
by htg engineer » Sat Feb 27, 2010 7:23 pm
Don't worry about it - that's down to the RGI you employ to fit the boiler to sort out.
htg
It is currently Fri Nov 15, 2024 1:30 am
