Loss of water accompanied by air lock after turning water of
AJPAS
by AJPAS » Mon Jan 25, 2010 3:37 pm
I have an apartment on the 4th floor. Water is pumped up. My problem is that if I turn off the water at the stop cock to the electric unvented hot water cylinder ( as I'm told to ), when I return to the flat and turn on the stop cock, I hear a few gallons of water rushing into the cylinder, and there are air locks at the taps. Where did the water go to? I have risked not turning the water off because I am alarmed. Not a good idea in this weather. The builder brought the plumber to see it,and claim the system is working properly. Any ideas please ?
by stoneyboy » Wed Jan 27, 2010 8:51 pm
AJPAS,
If a pressure relief valve if fitted to the cylinder this may not be sealing correctly, trace where it vents to and see if there is regular flow out of it.
It is currently Thu Jan 09, 2025 8:01 am
