sink drainage
stuartmcc
sink drainage
by stuartmcc » Fri Jan 29, 2010 3:43 pm
I have a bathroom sink which doesnt drain properly. It seems to drain for a few seconds then stops. The water then remains and drains over quite a long period. I have tried to check for blockages. and looked under the floorboard at the plastic drain pipe. I notice that about 3 feet from the sink the plastic pipe is joined to a lead pipe and that has a small u shape loop in it with a screw drain hole at the base. I thought this might be causing an air lock. Is there any purpose to this loop and could I just remove it.
plumbbob
by plumbbob » Sat Jan 30, 2010 12:46 am
The "U" shaped trap should not be there and will be responsible for all sorts of problems. It is possibly where your pipe is blocked - it wouldn't surprise me!
It is currently Mon Dec 02, 2024 2:45 pm
