Power for an Electric Shower
Larkum
by Larkum » Mon Feb 01, 2010 9:44 pm
Hello All,
I am Planning on fitting an electric show into my home, after reading a guide it stated that I had to install the shower on its own line from the.
My Question: Would it be ok to run the shower off of the old immersion heater power source?
My Home was converted from an old back boiler system to a combi boiler by the local council a few years back, as a result my Hot water tank was removed and the power source for the immersion heater was left doing nothing.
Thank you for your Help
Larkum
by stoneyboy » Tue Feb 02, 2010 8:31 pm
Larkum,
"Would it be ok to run the shower off of the old immersion heater power source?" No definately not. You will need either 6 or 10mm T&E depending on the model of shower you choose and the length and routing of the cable.
It is currently Thu Dec 05, 2024 3:06 am
