Blocking an upstairs fireplace
Tangler
by Tangler » Wed Feb 03, 2010 6:28 pm
I have a fireplace in the bedroom of my house and I want to fill it in and decorate over it.
The fireplace in the living room below is still in use with an open fire.
I'm assuming the two fireplaces are connected somehow.
What should I use to block the hole, and will I need an air brick if the downstairs hearth is still open and in use?
by stoneyboy » Fri Feb 05, 2010 7:11 pm
Tangler,
"What should I use to block the hole" aerated concrete blocks.
"will I need an air brick " yes.
Tangler
by Tangler » Mon Feb 08, 2010 11:24 am
Many thanks
TheDoctor4
Help from DIY Doctor!
by TheDoctor4 » Fri Jun 25, 2010 7:19 pm
Let DIY Doctor help you to find quotes from vetted and trusted tradesman local to your area. Visit our Find a Tradesman page: https://www.diydoctor.org.uk/find_tradesmen/
It is currently Fri Nov 15, 2024 5:52 pm
