changing a new bathroom suite
adviceneeded
by adviceneeded » Mon Jun 04, 2007 9:56 pm
hi , hope someone can answer this easy question for me?
Im about to install a new bathroom suite but im NOT changing the radiator in the bathroom.Do i need to drain down the whole system i.e the central heating to install the new bathroom suite before i start work???
bazza
change bathroom suite
by bazza » Tue Jun 05, 2007 10:21 am
hi the central heating is run of a seperate curcuit so you dont need to drain it bazza
by htg engineer » Tue Jun 05, 2007 12:03 pm
if you're not moving the radiator there's no need to drain the heating system,
just turn off cold supply and let hot taps run until they stop (if a combi boiler just turn off cold supply there'll be no hot water to drain)
To remove radiator turn off both valves on radiator and undo the nuts, there'll still be water in the radiator but this can be emptied outside.
It is currently Mon Dec 23, 2024 8:22 am
