15mm copper pipe joint to very slightly larger diameter pipe
8 posts   •   Page 1 of 1
Jeff Worsnop
by Jeff Worsnop » Sat Feb 06, 2010 5:12 pm
Help/advice please.
Trying to replace a length of copper pipe feed to utility room tap. 15mm and 15mm to 1/2inch connectors do not fit the old pipe which I measure has an external measurement of 5/8inch or 17mm.
I would be grateful for ideas where to source a suitable fitting either compression or soldered.
Jeff
by htg engineer » Sun Feb 07, 2010 2:30 pm
It'll be 16mm OD - a normal 15mm compression connector should work, or buy a imperial to metric connector.
htg
Jeff Worsnop
by Jeff Worsnop » Sun Feb 07, 2010 4:43 pm
[quote="htg engineer"]It'll be 16mm OD - a normal 15mm compression connector should work, or buy a imperial to metric connector.
htg[/quote]
Thanks for reply but unfortunately not.
Compression cap and olive will not fit. Effected temp repair by filing the end of the pipe and hammered a stop end with built in solder over it. No solder came out of the joint and there is a small amount of water weeping out so will have to be redone when I can come up with a solution. Feel like wacking in a piece of plastic and filling in the end with solder! But I guess there must be a more elegant way to do the job.
Jeff
acsimpson
by acsimpson » Mon Feb 08, 2010 9:31 am
If you can't trace the pipe back and replace the entire length of it then try googling "5/8 compression fittings" looks like there's a few options there.
Jeff Worsnop
by Jeff Worsnop » Tue Feb 09, 2010 2:39 pm
[quote="acsimpson"]If you can't trace the pipe back and replace the entire length of it then try googling "5/8 compression fittings" looks like there's a few options there.[/quote]
Thanks. Googled accordingly.
Couldn't see end stops. Plenty of couplings but not what I need.
Jeff
acsimpson
by acsimpson » Wed Feb 10, 2010 3:47 pm
Leaving a dead leg or unused piece of pipe in the system is generally thought of as a bad idea, however if that's what you have decided to do in your own house no one will stop you.
You could try combining an imperial reducing coupler with a 10mm blanking plate as follows.
"coleparmer.co.uk/catalog/product_view.asp?sku=3141257"
and
"toolstation.com/shop/Plumbing/Compression/Compression+Nut+10mm/d20/sd2697/p15820"
Not the cheapest solution but easier to undo in the future than soldering it closed.
Jeff Worsnop
by Jeff Worsnop » Thu Feb 11, 2010 7:17 pm
[quote="acsimpson"]Leaving a dead leg or unused piece of pipe in the system is generally thought of as a bad idea, however if that's what you have decided to do in your own house no one will stop you.
The pipe supplied a defunct utility room via the garage. I still need it to supply an outside tap and 2 garden watering units from the garage. I would be delighted to run the tap from the end of the pipe but that would seem a more difficult proposition than simply (ha ha) putting an end stop on it. I am only trying to make the best of a bad job without too much disruption and expense. Of course I could get someone to replumb from the pipe that supplies the central heating boiler in the garage but all I asked was what I thought was a simple question. The phrase ""if that's what you have decided to do in your own house no one will stop you", is a rather strange conclusion to reach badly expressed.
Anyhow thanks for your advice for which I am grateful.
End of thread methinks.
Jeff
Harson
Re: 15mm copper pipe joint to very slightly larger diameter
by Harson » Thu Oct 06, 2011 12:52 pm
Bending machines are available to suit the full range of copper pipe from 6 to 54 mm external diameter - they are considered essential for pipes over 22 mm - thankfully most diy'ers will seldom need to work with these larger sizes.
It is currently Fri Jan 10, 2025 6:35 pm
