uneven doorjamb 1\4 inch higher on 1 side
selfindulgance
by selfindulgance » Sat Feb 06, 2010 6:07 pm
I just built a wood door with a large satined glass panel to go between my kitchen and pantry. There is a 1/4 inch difference in height between the right and left side of the door jamb [floor slope after 57 years]. I would rather not recut the door on an angle. Should I take out the doorframe and reduce the higher side by 1/4 inch [making it a 'square' opening]? Suggestions as to the correct way to 'square' this doorway are very welcome.
Thank you, in advance, for your time,
Gerry
by stoneyboy » Sun Feb 07, 2010 8:47 pm
selfindulgance,
1. chisel off 1/4" on the shorter side.
2. fit a wedged shaped piece of wood to correct the difference.
3. removing and refitting the frame not advised
selfindulgance
by selfindulgance » Mon Feb 08, 2010 5:19 pm
thank you.
g
carpstu
by carpstu » Tue Feb 16, 2010 8:16 pm
i would cut the diffrence of the bottom then wedge the top down and level the top to match the other side you may well have to cut or pull out the
fixings
It is currently Mon Nov 25, 2024 4:29 pm
