storage heaters going off while others work
jaki
by jaki » Sun Feb 07, 2010 9:46 am
i have five storage heaters that heat the house fine. however every few months two of them stop working. I get the electrician and he finds nothing wrong with the wiring, the heaters, the fuses - nothing. however he jiggles a few wires going into the fuse box ,tightens some screws and the heaters come on again - last night they stopped working again.
What is wrong and how do i get it fixed?
by stoneyboy » Sun Feb 07, 2010 8:57 pm
jaki,
If the "electrician" can solve the problem doing what you describe then you should get in a different electrician.
Ollie555
by Ollie555 » Thu Feb 18, 2010 8:19 pm
The problem is the internal stat in the storage heater, basically it a spring loaded bimetal strip. if clothes are left on the heater it heats up and trips the power to the storage heater.
its easily reset by pushing on the stat.
It is currently Fri Jan 17, 2025 7:32 am
