Crack reappears...
bristol
Crack reappears...
by bristol » Wed Feb 10, 2010 12:45 pm
Hello folks
I have a 7 year old house with dry lined walls.
The previous owner took out the wall between the kitchen and dining room.
A fairly crappy effort was made to reinstate the walls that remained, and a crack continues to appear where he plastered the gap between the kitchen wall and the dining room wall.
I have tried the initial polyfilla route, through to cutting out a fraction each side of the crack, inserting decorators caulk, covering with plasterboard tape and then skimming over the top - the tape remains intact but the plaster over it has a hairline crack almost as soon as it dries
I'm now thinking of 2000 grade lining paper, but maybe it will end up splitting?
Grateful for any thoughts/advice please.
by stoneyboy » Sat Feb 13, 2010 8:32 pm
bristol,
I would guess that the problem is that plaster has been used to join two walls which are dry lined. Cut back the plasterboard either side of the join and fit a new piece of plasterboard in the gap, replaster but you will probably have to do a skim coat with scrim tape.
chris_on_tour2002
by chris_on_tour2002 » Tue Feb 16, 2010 11:07 pm
may also need to insert an extra noggin.
It is currently Fri Nov 22, 2024 5:50 am
