PANEL RADIATORS
Dadwood
PANEL RADIATORS
by Dadwood » Fri Feb 12, 2010 8:15 pm
Hi, I expect you've had this question many times before but can you tell me please; What is the difference between a double panel single convector radiator, and a double panel double convector radiator? Is it something to do with the way the two panels are connected together? Thanks for any help you can give.
plumbbob
by plumbbob » Sat Feb 13, 2010 5:04 pm
Modern radiators have fins on the inside of the panels making them convector radiators.
A double single has one set of fins fixed to the front panel. Double double has fins on both panels.
by htg engineer » Sat Feb 13, 2010 7:36 pm
The convectors are the fins on the radiators, zig-zag bit of metal.
Double panel single convector, will have one set of fins between the two panels. A double panel double convector will have two sets of fins.
The fins trap and restrict the airflow - so heat is transferred to the air quicker.
htg
Dadwood
by Dadwood » Sun Feb 14, 2010 8:25 pm
Dear plumbbob and htg engineer, thank you both for your kind replies. Now I know how to tell the two types. Thanks again.
It is currently Mon Nov 25, 2024 11:11 pm
