WASHBASIN TAPS
Brian Read
WASHBASIN TAPS
by Brian Read » Mon Feb 15, 2010 10:39 am
Can anyone tell me how to access the body of a shrouded head tap on my bathroom washbasin?I need to repace the washers but although the "H" and "C" disc inserts can be prised out with a very small screwdriver this dosen't give access to the screw on the tap body.
I suspect the rotating tap head is a push fit on the spindle but don't like to try and knock it off in case I create anither problem.The taps were fitted twenty years ago so will probably be reluctant to move and will need some gentle persuasion
Can anyone advise please?
by stoneyboy » Tue Feb 16, 2010 6:53 pm
Brian Read,
If they definitely are push fit use an adjustable spanner under the heads to prise them loose.
It is currently Mon Jan 06, 2025 2:00 am
