Radiators
mankind
Radiators
by mankind » Mon Feb 15, 2010 5:02 pm
hi everyone,
The pipework going to and from my radiators are at different temps; one is cold and the other is hot, is this correct ?
Also and i think because of the above the bottom of the rad is cooler than the top.
any ideas ?
plumbbob
by plumbbob » Tue Feb 16, 2010 6:19 pm
There is supposed to be a difference between the input and output pipes and this is quite normal.
Where your system differs is the amount of variation as it should only be a few degrees. Now if the radiators are cold at the bottom and the output is much cooler than the input, you have a circulation problem in the system. It could be simply a balancing problem.
There are other possibilities but as you have offered scant information it is rather difficult to be more precise.
mankind
Radiators
by mankind » Wed Feb 17, 2010 3:35 pm
Hi plumbob,
what further information do you require ? and how do i balance my system ?
Mankind
plumbbob
by plumbbob » Wed Feb 17, 2010 6:13 pm
The DIY projects section on this website has a topic explaining how to balance radiators.
For proper help you need to give as much information as possible when asking a question. Type of boiler? Description of heating system.? Does it have a hot water cylinder? Is it gravity or fully pumped? Are there zone valves? If so, one or two? How old is it? Is this a new problem? Has anything changed such as new radiators?
