Toilet cistern slow in filling up
sulahaka
by sulahaka » Tue Feb 16, 2010 1:42 pm
My toilet cistern is very slow at filling up between flushes. any ideas please
Dave From Leeds
by Dave From Leeds » Thu Feb 18, 2010 9:00 am
Need a bit more information to answer this. Is the toilet cistern supplied from a cold water storage tank or directly from the mains? Has anything been changed with the system recently?
If mains-fed, you could have low water pressure. If either it could be that there is some kind of restrictor in the ball valve feed which has become clogged up.
kay-jay
by kay-jay » Fri Feb 19, 2010 2:14 pm
hi,
i had a suimilar problem. lift the lid to your w.c cistern if you have the old type ball valve, a common problem is a build up of scale deposits from the water. turn off your water supply or isolating valves if you have them, the ball valve can then be unscrewed and separated into its composite parts if you see any scale gently use a wire brush to remove this. then reassemble and turn on your water supply.
some more modern (bottom filling) float valves are fitted with a filter screen at the point where the water supply enters the cistern. sometimes these can become filled with debris which restricts the flow of water. it is sometimes necessary to remove the cistern to get reasonable access to service this tho.
kay-jay
It is currently Wed Nov 27, 2024 1:50 am
