Bath Traps
raypeggy
Bath Traps
by raypeggy » Wed Feb 17, 2010 1:17 pm
Is it O.K to fit a shallow bath trap where the waste runs into a soil stack.
Looking at one in my local d.i.y shop the instructions said "Suitable For Running Waste Water Into A Gully"
Clarification on this(Water Regs.) Etc. would be much appreciated.
Thanks---Ray
by stoneyboy » Sun Feb 21, 2010 6:44 pm
raypeggy,
Since you are going direct into a soil stack you should use a trap with a 3" seal. If it is impossible to get such a trap under the bath try using a Hep2O trap - they can be fitted horizontally - it must be fitted up the correct way.
It is currently Sun Nov 24, 2024 7:01 am
