Bonding out (or not)
richrich
by richrich » Tue Jun 05, 2007 3:04 pm
I have a 12 x 12 room what has a inset door area into the room. Because of this I have an external corner that then runs out into the 12 foot wall.
The walls are all currently plastered and painted. They have taken knocks and bumps over time and I would prefer to have them re-skimmed rather than spend hours messing about trying to patch fill and sand all the small marks and holes.
My question is this, if I put an angle bead from floor to ceiling on this external corner and bond it, I can then bond the inside around the door as it is only about 14 inches from bead to back wall with bonding plaster and feather board off ready for a final skim coat but what about the other side of the bead that opens up onto 12 feet of wall ?
I do not need to bond out 12 feet of wall that is already plastered and surely the depth of the angle bead would be too much for skimming along.
Can anyone advise the best way to work from the angle bead out onto a large open wall that is already plastered and not in need of bonding out.
thedoctor
by thedoctor » Fri Jun 08, 2007 7:23 am
No need to "bond" anything from what you say Rich. You can buy top coat beads which are angle beads for skim plaster so all you need to do is tack them or stick them on with a little skim and simply prepare and skim the wall.
Ross Boseley
bonding out
by Ross Boseley » Wed Jun 13, 2007 8:43 pm
as the doctor says mate you just need to pva your wall and reveals tack a thin coat angle bead on the inside and skim the wall. If you want to learn how before trying we are now offering a special summer rate at the plastering centre Bruntingthorpe of £250 with a free pre worn marshall town trowel.
It is currently Sat Nov 23, 2024 7:01 pm
