Ring beam joints?
barnacle bill
Ring beam joints?
by barnacle bill » Thu Feb 18, 2010 3:00 pm
Hello all, this is my first post and i hope you can help.
I'm building a porch and have a 8x2 ring beam to take the roof above.
I have 2 oak posts offset from each corner and would like to know the best way to join the ring beam at the corners. Obviously i want the strongest possible corner as it will be taking the rafter.
I was thinking of a mortice and tenon or dovetail joint and then braced inside.
What do you think.
BB. :)
by stoneyboy » Sun Feb 21, 2010 7:04 pm
barnacle bill,
Assuming your 8x2s are with the 8 vertical I would suggest using coach bolts and toothed timber connectors.
It is currently Fri Nov 22, 2024 10:57 pm
