Kitchen mixer tap
davejohnparkes
Kitchen mixer tap
by davejohnparkes » Sat Feb 20, 2010 8:40 pm
I am going to buy a new kitchen mixer tap which states: Minimum pressure requirement 1 BAR (not suitable for low pressure/gravity fed systems)
I have a combi-boiler, no emersion.
The combi is set at 1.9 BAR so I'm hoping this system will be okay?
Cheers.
James1000
by James1000 » Sun Feb 21, 2010 6:03 pm
If you have a Combi already its very likely that you already have 1 bar or more ,i doubt it would operate on anything less.
The 1.9 bar i assume your referring to is what the needle on the gauge is showing on the front of your boiler this gauge shows the water pressure in your heating system ,which should be on around 1 bar when cold then it will rise up as the water in the system expands as long as its not in the red its OK.
davejohnparkes
Tap - new
by davejohnparkes » Mon Feb 22, 2010 1:29 pm
Yes I was referring to the guage on the front of boiler. Many thanks for your reply James.
chris_on_tour2002
by chris_on_tour2002 » Mon Feb 22, 2010 2:12 pm
if you had less that 1 bar i think you'd know about it - the pressure would be appalling. i have 3 bar where i live (well, at 3am anyway! peak times it's closer to 2 bar) and it's only just about tolerable.
It is currently Fri Nov 22, 2024 12:39 pm
